Enscape Renderer Error
The GTX 1650 is supported by Enscape, but if budget allows I’d recommend going with something like a 1660 Ti - May I ask what your budget allows, estimated?
In such a case, please kindly send us a Feedback report so that we can further identify the cause behind this specific problem. The RTX 2060 is supported by Enscape and is also a rather decent card to use with our plugin! So, thanks a lot in advance for submitting the said report, we can then troubleshoot the cause behind it as quickly as possible.
Thanks for your reply, I did send the feedback report and got an answer, some OUT OF MEMORY issue that is caused by a bug that does not consider the amount of VRAM taken by the geometry in a project, the developers are working on this issue I believe.
Sir !
For only enscape i can go only upto 75000 in Indian rupees, please suggest me a good laptop ???
You will not find a good gaming laptop for 75000 INR / $1000USD.
Minimum $1800 https://www.razer.com/gaming-laptops/Razer-Blade-15/RZ09-0410AE22-R3U1
Better $2000 https://www.razer.com/gaming-laptops/Razer-Blade-15/RZ09-0410BE22-R3U1
Please tell me now for Enscape which 4 graphics card is best ?
Nvidia GTX 1650
Or
Nvidia RTX 3050 ???.
No to GTX.
RTX 3060 as minimum
Best = Nvidia 3080Ti or 3090 RTX. https://gpu.userbenchmark.com/
As mentioned by Phil, ideally you want a machine with one of the more powerful GPU’s on the market (Especially for VR), but if your budget only allows for an RTX 3050, I’d say go with that!
Be aware that you may have to lower the rendering quality overall in Enscape if you experience any performance problems, and/or due to the card only having 4GB of VRAM, larger scenes may have to be reduced in scope.
Still, you will have a decent experience nonetheless with a 3050, although, again, if your budget would allow it, go with a 3060, 3070, or higher instead. :slight_smile:
Thank you Demain Sir !
Finally thank you All Enscape team for such a lovely software !
Love from Kashmir, India
My last year Rendering !
Congratulations! Happy to see you are able to use Enscape now!
kindly help !
I have to decided to buy this laptop for enscape.. my projects are not heavy.
Lenovo Ideapad Gaming 3 Ryzen 5 Hexa Core 5600H - (8 GB/512 GB SSD/Windows 11 Home/4 GB Graphics/NVIDIA GeForce GTX 1650/120 Hz) 15ACH6| 15ACH6D1| IdeaPad Gaming3 15ACH6D1 Gaming Laptop
Please tell me can i go for this laptop ? Please tell me ?
The NVIDIA GeForce GTX 1650, in this case, is basically the minimum we recommend, but since you say your projects are not that heavy/large, and budget does not allow for something more powerful, you can definitely use this laptop in combination with Enscape - Just make sure to dial down the Rendering Quality in the Visual Settings whenever you experience performance problems. :slight_smile:
Hello, sorry my bad english.
this weekend i change my old GTX 1070ti, for a new RTX 3090, i dont change any more on my desktop pc.
Install RTX 3090, update Geforce Experience V.3.27.0.112, update drive v531.79
Use Revit + Enscape
And now i have this error. " Error compiling shader"
Welcome to our Forum.
In this case I also would reccomend trying to use something like DDU (display driver uninstaller) to do a clean uninstall of any drivers currently on your machine, and then re-installing the latest drivers for your RTX 3090. Otherwise issues can occur if there are still leftover files/drivers from your 1070Ti.
You can acquire display driver uninstaller here for free:
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
If that doesn’t do the trick at all please also submit a feedback report with logs to our support team which should help with troubleshooting this further then:
https://learn.enscape3d.com/blog/knowledgebase/using-the-feedback-button/
