Enscape rendering image but not saving it
Yesterday I don’t know what happened but enscape has suddenly stopped working kind of.
The viewport works perfectly fine but when I click “take screenshot”, it renders the image but after it is done, it doesn’t ask me for the save location like it used to before so I can not save my renders anymore. Can someone please help me fix it because this the only rendering software that works on my device flawlessly (well, used to).
I tried uninstalling and reinstalling but it did not help.
Hi @Rackmo
Welcome to our forum!
I have moved your thread to our bug and error section and deleted your other post regarding this.
Normally the window to choose a folder should come up before the image gets rendered.
However, if you don’t get this option anymore, could you check in our Visual settings under the Output tab if the Automatic Naming option is activated?
As this option will then automatically use the default folder.
Let me know if this is not the case, and please send us a feedback via the Enscape Feedback Button with a link to this thread in the description in that case.
@Rick_Marx thank you for the reply.
No, I do not have the automatic naming option enabled.
I tried going back to an older version and then back to the original and it was working perfectly fine but then once I closed enscape and opened it again, the no-save problem started again.
I really don’t want to go back permanently to an older version because v3.0 is just too good and I can’t keep going back and forth with the versions either.
So please let me know if there is a solution to this, I could really use some help.
@Rackmo
Could you in that case send us a feedback report via the Enscape Feedback Button.
Please also add a link to this thread in the description.
@Rick_Marx Done!! Hopefully it gets resolved soon :slight_smile:
