Enscape Rhino 7 glitch
Hi there-
Recently encountering this issue when launching Enscape within Rhino 7. Can someone shed some light on the source of this problem.
@davidmcoenpartners , welcome to our Forum.
Please make sure that the project itself is not located too far off the initial center itself - If it is, please try moving it to the initial starting area (the area you’d be located in when creating a new project).
If that doesn’t do the trick, please also update your GPU drivers. You can acquire new ones through either the NVIDIA or AMD homepage depending on your card. Windows itself may also display that they aren’t outdated, but that is often false so we recommend getting them from their respective official sites instead.
Finally, please also ensure that the ground plane you are using isn’t overly large (try reducing it in size), as that can also cause similar issues like seen in the image you shared.
Let me know if that also doesn’t resolve this behavior at hand!
Many thanks Demian!! I think we finally got to the bottom of this. Thanks for the prompt reply.
Best,
David
You’re very welcome and I’m glad to hear that - May I ask what caused it in the end? :slight_smile: Or otherwise, what resolved it?
