Enscape stuck on the initial page
I am using Windows 11 virtual machine on MAC M1 2021 machine using Parallels which is just like BootCamp. Also, I am running Revit and Autodesk which work just fine, both are windows based applications on the same machine. Unfortunately, I have an issue running Enscape on a windows machine (via Parallels). It actually starts fine, but gets lost and stays at the initial page. I can see the following path
C:\Users<myname>\AppData\Local\Programs\Enscape\Bin64\Enscape.HostLauncher
That indicates Enscape has been installed.
Hi @agooyabadi
Welcome to our forum.
We are currently developing Enscape for Mac and hope to release the version this year - at this time there is no specific release date available. If you would like to sign up to our Mac mailing list, to receive an update once the version is released, you can do so here.
Unfortunately, seeing that you have an M1 chipset, running Enscape is not currently possible due to Apple having pulled Bootcamp support for these M1 chipsets and Parallels / VMware Fusion is not yet supporting OpenGL4.4 (Older Enscape versions) or Vulkan 1.1, which Enscape requires to run.
