When I enable Revit Live Camera, Enscape’s view is not exactly same with Revit’s view. It seems that the cameras in both environment are not the same. Is there a way to make sure Enscape’s camera (location, pose, and view frustum) is exactly same with Revit’s? Or how can I get the parameters of Enscape’s camera?
Thanks,
Enoch
The field of view in the Revit camera does not have as careful control as the Enscape camera.
You can turn on the Enscape camera in Revit. If you move the Enscape camera in Revit, it will move the Enscape camera in Enscape. You can also control, the elevation, orientation and pitch of the Enscape’s camera in Revit.
https://wordpress-community-media-prod.s3.amazonaws.com/community/wp-content/uploads/2022/03/31110143/revit_live_camera_enscape.mp4
Turning on the Enscape camera inside Revit is particularly useful when careful camera control and key frame placement is required for creating animated sequences.
It’s also possible to open the Enscape camera and edit in the Revit family editor. This is useful for making the Enscape’s camera more visually apparent inside of Revit.
https://www.linkedin.com/pulse/five-minutes-one-simple-tweak-improve-live-camera-tracking-phil-read/
