Entire Revit model not visible in Enscape window
This is the first time this has happened. The entire model (created in Revit) is not visible in the Enscape window but is visible in the default Revit 3D view.
All graphics drivers are up to date as well as Enscape and Revit.
I cannot see why this would be. It’s only on this model and really can’t figure out what’s gone wrong.
Steps to success.
  • Close Enscape
  • Delete Default 3D View
  • Create new Default 3D View
  • Make new 3D View Active Document
  • Start Enscape
I have noticed some weirdness in Revit when you’re switching between perspective an orthographic view. It tends to create zooming artifacts which can hide the project in Enscape. You should also try to switch from perspective to ortho. Then zoom to fit in Revit. Then start Enscape.
