Hello, I encountered an issues with the env fog in conjunction with light selects render elements. I have scene with an env fog and a procedural map to control the density of the fog. The fog doe not appear in the light selects of the two lights in the scene. When I remove the map it works fine. I tested it in 3ds Max as well and it works in Max but not in Maya. In 3ds Max I can use a noise map to control the density and the fog appears in light selects as well. Is it a bug in Maya?
We are using: Maya 2019.3.1
[2020/Jun/24|15:47:17] V-Ray: V-Ray Next for Maya, update 2.2 version 4.30.02 from Apr 15 2020, 17:49:01
[2020/Jun/24|15:47:17] V-Ray: V-Ray core version is 4.30.03
fog with noise map
Light select - no fog
fog without map in density slot
light select, this time with fog
thanks
Florian Dubiel
