I’m working on a scene maya2011.
I’m using the NightlyBuild from 22 dec.
The lighting is an indoor hall with Raylight from outside
I created 2 RectLight (see fig) and set parameters light figs joined with the post.
I was looking for set renderSettings to get no Grain into the fog and i had thoses artefacts followed.. (VueCameraBug.png)
I rendered a renderElement (Zdeph) which is perfectly rendered (no artefacts)
May be someone knows this problem.
Please, if someone at Chaosgroup could light me about which value i have to set to have a rendering with no grain without having 7hours of rendering…
This frame was rendered in 1 h 20mn on an octocore and 16 g Ram … where is my mistake?!
Thanks all and happy newyears with Vray
Pierre
I forget to join the log:
Starting “/usr/autodesk/maya2011-x64/bin/maya”
mental ray for Maya 2011
mental ray: version 3.8.1.33, Aug 20 2010, revision 124793
[2011/Jan/11|15:43:15] V-Ray: V-Ray for Maya version 1.50.SP1 from Dec 22 2010, 07:16:19
[2011/Jan/11|15:43:15] V-Ray: V-Ray core version is 2.00.01
Initializing V-Ray for Maya
File read in 5 seconds.
File read in 0 seconds.
Result: XXX/volumetrique.mb_RyYu59_vrayBatch.mb
Warning: Found camera ddm__v__066_903__p__camera__s__camera_maya__d__camera:stereoCameraLeftShape.
V-Ray: Starting render
[2011/Jan/11|15:43:20] V-Ray: Loading plugins from “/usr/autodesk/maya2011-x64/vray/vrayplugins/libvray_*.so”
[2011/Jan/11|15:43:22] V-Ray: 100 plugin(s) loaded successfully
[2011/Jan/11|15:43:22] V-Ray: Finished loading plugins.
[2011/Jan/11|15:43:22] V-Ray: Exporting scene to V-Ray.
[2011/Jan/11|15:43:22] V-Ray: Parsing light links time 0h 0m 0.1s (0.1 s)
[2011/Jan/11|15:43:23] V-Ray: Translating scene geometry for V-Ray
[2011/Jan/11|15:43:23] V-Ray: (Estimated time remaining: 0h 0m 0.5s): 17 % completed
[2011/Jan/11|15:43:23] V-Ray: (Estimated time remaining: 0h 0m 0.5s): 24 % completed
[2011/Jan/11|15:43:23] V-Ray: (Estimated time remaining: 0h 0m 0.9s): 30 % completed
[2011/Jan/11|15:43:23] V-Ray: (Estimated time remaining: 0h 0m 1.3s): 40 % completed
[2011/Jan/11|15:43:24] V-Ray: Total time translating scene for V-Ray 0h 0m 1.4s (1.4 s)
[2011/Jan/11|15:43:24] V-Ray: Rendering.
[2011/Jan/11|15:43:24] V-Ray: Pre-render export.
[2011/Jan/11|15:43:24] V-Ray: Pre-render export done.
[2011/Jan/11|15:43:24] V-Ray: Rendering frames.
[2011/Jan/11|15:43:24] V-Ray: Updating frame at time 1.00
[2011/Jan/11|15:43:24] V-Ray: (Estimated time remaining: 0h 0m 1.2s): 11 % completed
[2011/Jan/11|15:43:24] V-Ray: (Estimated time remaining: 0h 0m 0.8s): 23 % completed
[2011/Jan/11|15:43:24] V-Ray: (Estimated time remaining: 0h 0m 0.5s): 41 % completed
[2011/Jan/11|15:43:24] V-Ray: (Estimated time remaining: 0h 0m 0.2s): 67 % completed
[2011/Jan/11|15:43:24] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 92 % completed
[2011/Jan/11|15:43:24] V-Ray: Total time updating frame 0h 0m 0.5s (0.5 s)
[2011/Jan/11|15:43:24] V-Ray: Preparing renderer…
[2011/Jan/11|15:43:24] V-Ray: Preparing scene for rendering…
[2011/Jan/11|15:43:24] V-Ray: Preparing scene for frame…
[2011/Jan/11|15:43:24] V-Ray: Compiling geometry…
[2011/Jan/11|15:43:24] V-Ray: Building static raycast accelerator…
[2011/Jan/11|15:43:24] V-Ray: SDTree statistics:
[2011/Jan/11|15:43:24] V-Ray: Total number of faces stored: 64327
[2011/Jan/11|15:43:24] V-Ray: Max tree depth: 33
[2011/Jan/11|15:43:24] V-Ray: Average tree depth: 17.4214
[2011/Jan/11|15:43:24] V-Ray: Number of tree nodes: 21727
[2011/Jan/11|15:43:24] V-Ray: Number of tree faces: 174701
[2011/Jan/11|15:43:24] V-Ray: Number of tree leafs: 8455
[2011/Jan/11|15:43:24] V-Ray: Average faces/leaf: 20.6624
[2011/Jan/11|15:43:24] V-Ray: Memory usage: 7.49 MB
[2011/Jan/11|15:43:24] V-Ray: Rendering image…
[2011/Jan/11|15:53:07] V-Ray: (Estimated time remaining: 1h 27m 25.2s): 10 % completed
[2011/Jan/11|15:59:16] V-Ray: (Estimated time remaining: 1h 2m 39.1s): 20 % completed
[2011/Jan/11|16:00:21] V-Ray: (Estimated time remaining: 0h 38m 6.0s): 30 % completed
[2011/Jan/11|16:07:18] V-Ray: (Estimated time remaining: 0h 35m 32.1s): 40 % completed
[2011/Jan/11|16:07:55] V-Ray: (Estimated time remaining: 0h 23m 55.9s): 50 % completed
[2011/Jan/11|16:17:17] V-Ray: (Estimated time remaining: 0h 22m 35.1s): 60 % completed
[2011/Jan/11|16:28:34] V-Ray: (Estimated time remaining: 0h 19m 21.0s): 70 % completed
[2011/Jan/11|16:31:34] V-Ray: (Estimated time remaining: 0h 12m 2.4s): 80 % completed
[2011/Jan/11|16:47:18] V-Ray: (Estimated time remaining: 0h 7m 5.9s): 90 % completed
[2011/Jan/11|17:03:22] V-Ray: Number of raycasts: 3560781222
[2011/Jan/11|17:03:22] V-Ray: Camera rays: 2953789081
[2011/Jan/11|17:03:22] V-Ray: Shadow rays: 606992141
[2011/Jan/11|17:03:22] V-Ray: GI rays: 0
[2011/Jan/11|17:03:22] V-Ray: Reflection rays: 0
[2011/Jan/11|17:03:22] V-Ray: Refraction rays: 0
[2011/Jan/11|17:03:22] V-Ray: Unshaded rays: 0
[2011/Jan/11|17:03:24] V-Ray: Successfully written image file “volumetrique_masterLayer_cam_066_903_0left_V5.0001.exr”
[2011/Jan/11|17:03:24] V-Ray: Total frame time 1h 20m 0.3s (4800.3 s)
[2011/Jan/11|17:03:24] V-Ray: Total sequence time 1h 20m 0.3s (4800.3 s)
[2011/Jan/11|17:03:24] V-Ray: Render complete
[2011/Jan/11|17:03:24] V-Ray: ========================
[2011/Jan/11|17:03:24] V-Ray: Clearing exporter memory…
[2011/Jan/11|17:03:24] V-Ray: Total time clearing exporter memory 0h 0m 0.0s (0.0 s)
