Environment bug
Hi, guess who again :slight_smile:
I have an issue using the environment overrides, Refraction and Reflection overrides are not working, VFH only uses the override if you use it in the Background entry. And of course this is not what we need.
VFH:
3dsMax:
Can I get a fix for this ASAP please?
Best,
David.
What is the toggle state on the node? Is it turned on?
Oh boy…I did not see those…:frowning:
But i have to say that, when you create the “Env” node and you get that image file already connected to it, is highly missleading!
This default setup makes me think the “envImageFile” will automatically work on BG, GI, reflection and refraction.:
Still, my bad, and thanks for the pointer @bdancer .
Best,
David.
