Environment Mode of Vantage
Hi
I’ve tried the new Chaos Vantage released just before, it’s pretty cool. When i watch the video about introducing Lavina BETA on youtube, i notice that in BETA version there is a Physical Environment mod option which is quite similar to Vray sky map, but now i can not found it in the Vantage 1.0.
Is that something i missed or you just removed this option for some reason?
Billd
Hi yi_xiang
The Physical Sky mode in the Environment tab is only present if there is a sky model in the opened .vrscene. If you open a .vrscene without a V-Ray sky the option will not be available.
Alexander
Actually you need just a V-Ray Sun light in your .vrscene for the 'Physical Sky" option to show up.
The reason for this is that creating lights in Vantage is not yet possible and the 'Physical Sky" needs a sun light from which to get its properties.
Greetings,
Vladimir Nedev
Thanks for your prompt reply, and i found the Physical Sky in Vantage.
Thanks again.
