Hi guys!
Just bought one node to install in my iMac and it seems that it isn’t working.
I get this error message.
error: DR request received from client xxx.xxx.x.xx using V-Ray version (60021). Render server V-Ray version (61002).
Can anyone help please?
Thanks in advance
Bruno
Hello, its shown in the error message, you have two different versions of V-Ray and the distributed rendering works only with identical versions. Use the same installer on both computers otherwise it won’t work.
I can understand the concept, but I can’t find a solo version for C4D and a Standalone with the same version to manage to preform distributed rendering…
If I update both with last versions ( vray for c4d and standalone) I cant have similar versions…
Any ideas?
Thanks in advance !
Bruno
Use the regular V-Ray for Cinema 4D installer not the standalone. During the installation you can select to install it as a standalone. On the main machine install as workstation on the render node install as standalone using the same V-Ray for Cinema 4D installer. That way you will have the same version on both.
