Hi, I come back with a new project and a new issue with Corona Render.
There are very large differences between workspace and Interactive rendering, please fix this error.
I deleted the object on which the error occurred, I built it again and still for nothing. I deleted the texture, I put it again and nothing. Please investigate and solve the problem. This error also occurs in the final rendering. I do not understand where it comes from but it’s a short circuit between Corona and Cinema 4D.
PS I use the latest version of Corona Render
Hello beanzvision, thank you for the answer, as usual, very quickly, I have marked the error that appears, it is not seen in the workspace but it appears in Interactive render and in the final rendering. Normally that gray area does not have to be, is it a texture error? I do not understand how it appears
From what you think it can be
Ah yes, now I see it. Yep, that’s a mapping issue. Easy to fix though. Just make a new material 255 white as this is the same as your label and stack it behind the label material.
