What is the problem?
Corona A6. Same error to! Win 7 X64, 3dsmax 2014 sp5,https://dl.dropbox.com/s/gne3bks1kj8rjpr/shot_140318_151103.png
https://dl.dropbox.com/s/udh57t2lhsilxf0/shot_140318_151037.png
There is no solution?
My fellow has a same error!!
A5 is working well..
Do you have windows updates installed? DOes this test runs ok? http://corona-renderer.com/stuff/AVX2check.exe
The problem was solved after the update.
Thanks Keymaster.
I’ve installed all updates. Unfortunaly avx2check runs but it crash. May be it helps, some log error window
( Module name in error: MSVCR120.dll
Version of the module with the error: 12.0.21005.1)
If it still crashes, then there is still the problem. Maybe the update was hidden - try restarting computer few times and searching for new updates each time - they do not install all at once if I remember correctly
Thanks for your help! Lot of restarts and updates are helped! Corona runs without errors.
For lazy people like me can downloas the full SP1 of Win7 updates offline …
it’s vray usefull in the case OF Lan
Hi, the problem is as in the first post. AVX2 check crashes.
system:
vista buisness 64bit fully upadated
amd fx 8320
I tried to use legacy corona’s files, but the same problem with 3ds max 2012, 2014.
I tried many restarts of pc for invisible updates setup.
