I’m getting this error during simulation and it’s always the same frame. When I click OK, Max crashes and when reopened this frame works just fine.
I noticed something about Phoenix 5 being released. Is there something worth considering in a middle of a project. I’m currently working with liquid in a cyclone phenomena. It seems to be too much for Phoenix to understand.
If you simulated it, what version of Phoenix did you use, and what version do you use now?
If you simulated it with a newer version and opened it in an older version, chances are that it won’t open because the format is changing and older versions can’t possible know what the new things in the newer format could be.
Hmmm, if you used the same Phoenix version to create these caches, then it could be that your disk storage has problems and the cache files got corrupted. Maybe run a disk check tool just in case?
Here are the full changelogs with everything new and fixed since Phoenix 4.40 - there are changes to the solvers and some more options as well
Yess, there is a lot to be desired on the nightlies site. Something I imagined for years was to have some info for all the builds, like not only what’s new, but what are the known bugs or even regressions in every nightly…
I noticed, Phoenix don’t have perpetual licenses available anymore. I don’t know if I’m wealthy enough to move to rental licenses. What happens if rental license expires in a middle of a project, and I don’t have enough money to renew. I think the risks are too high for me. If there were possibility to upgrade my perpetual license I would have done that already.
