Error Rectangle Light
I noticed in the last update (5.20.06) an error where the light rectangle is circular by default, even choosing rectangular.
Hello @henriqueb ,
Do you have Directionality enabled? Also, does this also happen in a new project?
Can you send us a simple test scene where the issue is reproducible so we can have a look? When testing on my end I was not able to reproduce it.
Thank you.
Hello, @aleksandar.kasabov the error happens when using light intensity lower than 30. I work with the unit in watts. There was never this before. with the value 10 or 5 the light rectangle already shows the problem.
Hello @henriqueb ,
Thank you for sharing those details with us.
I tried reproducing this issue on my end (with the info you have provided) but I was not able to. Would you mind sharing a simple test scene where the issue is reproducible?
Thank you.
