I tried rendering Hair & Fur with Vray today. I got this error.
Here is the scene file.
Regards,
Mike
Regards,
Mike
does it go away if you choose a different option other then mr prim? That one is for mentalray.
It is fine rendered through the buffer. But the vray docs say to change it to MR prim to render natively. Quoted from the docs…
To enable native rendering of the Hair&Fur modifier, select the mr prim option for the Hairs parameter of the Hair and Fur render effect:
I thought this was strange as well. Thanks for the reply though.![]()
Regards,
Mike
well it says in the manual that one should indeed choose mr prim as an option for vray to use.
Percy percy…
interesting. color me corrected…
I can’t get hair and fur to even show up using mr prim. Nor have I ever. Am I missing something?
are you in max 2010? it only works in 2010…and sp3a
I have used it many times with MR, and it has always worked fine. But I would love to see it rendered in Vray.
Mabey I am missing a setting or two. I just tested this at home and still get the same error. Although it does still look damn nice rendered from the buffer.
Regards,
Mike
No, still on 2009. I had heard it worked with 2010, but assumed the vray docs hadn’t been updated so quickly to show that.
well its the code specific to 3ds max 2010, and as far as i understand it will not be supported for versions before that.
Yeah it only works in 2010 - the only reason there wasn’t support for it earlier was because 3dsmax didn’t expose it in the SDK or whatever before 2010.
Actually I got it to crash on a 4-core and an 8-core machine, but not on a dual one. The crash is somewhere in the hair code, so I’ll be sending the scene for investigation (our test scenes render fine though).
So further investigation showed that it only crashes in 3ds Max Design 2010; 3ds Max 2010 renders fine on all the machines.
Further on, it looks like a scene that is created in 3ds Max 2010, renders fine if loaded in 3ds Max Design 2010. However, scenes created in 3ds Max Design 2010 itself tend to crash.
I don’t understand,
will it be possible to use vray to render hair and fur?
Direct light, shadows, GI?
and if it’s the case, how do I get the sp3a to try that ? :o
Yes - only in 3ds Max 2010 though.
and if it’s the case, how do I get the sp3a to try that ? :oV-Ray for 3ds Max 2010 is available from the download section on the site.
great news.
but I have just install max 2010 and vray sp3a and I couldn’t obtain a licence.
Do I have to put the vray sp3a on the server to have the licence working? The licence of nomal sp3 isn’t enough ?
Best Regards
Stan
It is the same license as SP3.
Will this be fixed for Design ?
Regards,
Mike
is it because of the unstability or something like that, that the real annoncement hasen’t been done yet ?
I allready found some trubles, do you want that I send you those over ?
