I have a question about rendering Hair&Fur with Vray.
I have a scene with a large plot of grass. This grass is mostly a standard preset for Hair and Fur. In effects the Hair&Fur is set active, with the Hairs dropdownbox set to “mr Prim”. I tried to render this scene on multiple pc’s
At Home (Quadcore with 8gb ram, Nvidia GTX 360 and WinXP 64bit): It renders normally. Both in Geometry mode and mr Prim.
At work:
One group (Mostly Dual-Quads, 16-24gb ram with Quadro Cards and all WinXP 64bit): Does not render the hair in mr Prim mode, but they do render it with Geometry mode.
Second group (Dual-Quads and Dual Hexacore, both 24gb ram, Quadro Cards and Win7) Seems to even crash in mr Prim mode, but renders normally on Geometry mode.
One pc (Dual-Quad, 16gb ram, Quadro Card and XP64bit) seems to render the hair in mr Prim mode.
Why is this? It is the same scene all around, nothing has changed? According to Spot3d Vray Guide i should set it to Mr Prim. It looks better with that. Why do these pcs all have a different outcome?
All versions are using regular 3dsmax, not design.
Which V-Ray version is this? What is the dynamic memory limit set to in the V-Ray settings?
When you say that it does not render in “mr prim” mode, does it mean that the rest of the scene renders normally, but only the Hair&Fur is missing, or the scene does not render at all?
Ok; on those machines that do not render, is the 3ds Max root folder writable? For whatever strange reason, the Hair&Fur implementation writes a .dra file in a \hair sub-folder inside the 3ds Max root folder (I mean it’s strange that it writes the file there, not that it writes a file at all). If it cannot write this file, then the hair will not render.
I will make a note to try and use the temporary user folder for this, for future builds.
