error - set region problem
I left a render going last night on my local machine. Vray 1.5, Max 2009 x64. Here is a portion of the vray log:
[2011/Jan/13|17:22:42]         Light cache time interval is (-7.000000, 93.000000)
[2011/Jan/13|17:23:25]       Threads completed
[2011/Jan/13|17:23:25]       Merging light cache passes.
[2011/Jan/13|17:23:33]       Light cache contains 106452 samples.
[2011/Jan/13|17:23:33]       Light cache samples collected; compiling lookup tree.
[2011/Jan/13|17:23:33]       Prefiltering light cache.
[2011/Jan/13|17:23:36]       1 interpolation maps registered
[2011/Jan/13|17:23:36]       Rendering interpolation maps with minRate=-3 and maxRate=-2
[2011/Jan/13|17:23:36]       Setting up 4 thread(s)
[2011/Jan/13|17:36:09]       Threads completed
[2011/Jan/13|17:36:09]       Setting up 4 thread(s)
[2011/Jan/13|18:00:03]       Threads completed
[2011/Jan/13|18:00:03]       Calling endPass() on irradiance maps
[2011/Jan/13|18:00:04]       Calling prePassDone() on irradiance maps
[2011/Jan/13|18:00:06]       Image prepass completed.
[2011/Jan/13|18:00:06]       Rendering image.
[2011/Jan/13|18:00:06]       Setting up 4 thread(s)
[2011/Jan/13|21:11:44]         error: [VFBCore::SetRegion] Error writing render region to raw image file.
[RIFile::WTRegion] Error writing channel buffer.
[RIFile::WT3Float] Error writing tag header.
[RIFile::WriteTagHeader] Error writing to stream (33).
[2011/Jan/13|21:11:44]       Threads completed
[2011/Jan/13|21:11:44]     Calling endFrame().
[2011/Jan/13|21:11:44]       Entering endFrame().
[2011/Jan/13|21:11:44]         Broadcasting NOTIFY_POST_RENDERFRAME.
[2011/Jan/13|21:11:44]         Applying render effects.
[2011/Jan/13|21:11:44]         Number of raycasts: 1519524092
Yep, there seems to be a problem writing tiled OpenEXR files that take a long time to a network location. Writing to the local disk, or to a .vrimg file is not a problem.
Vlado,
Has there been any solutions to this problem? Apart from saving to VRIMG that is.
I am still getting this error but it is never consistent. Some machine render everything fine then others have the error. Then that same machine might render another image and everything works!
No, unfortunately I haven’t found a fix. But, OpenEXR 2.0 is just around the corner and hopefully it will handle this without problem :slight_smile:
