Error while installing
I am getting this error while installing the new Vatage 2.8.1, which seems to be related to Chaos Chosmos. But the main issue is if I try to install an older version, it already corrupts Chaos Chosmo. It’s even in my 3D Max version.
I didn’t fully understand your message but try uninstalling Cosmos from “Add/Remove programs” and see if Vantage 2.8.1 and the Cosmos embedded in it install correctly.
Sorry for the late answer, but too much work and then some vacations. So the issue is every time there is a Chaos Cosmos update it gets stuck in our company Antivirus/Spyreware hardware. THis is the only software that has this issue so I am not sure what’s different. For my main issue was that we had to manually delete everything Chaos Cosmos, and then re install V-Ray that will install chosmos.
