I’ve tried installing several Chaos products. Every time I try, the splash screen closes after a few seconds without displaying an error message.
This applies to
3ds Max 2025 and V-Ray 7.2000, 7.2004, and 7.2008, Phoenix 5.2400, Chaos Player
3ds Max 2026 and V-Ray 7.2008, Phoenix
I launched the installation from the desktop.
The host applications are working perfectly.
I’ve uninstalled the Antivirus program and restarted the computer.The problem persists.
There is an entry in Event Viewer (See below). Does this help with the diagnosis?
The problem does not occur on all of our computers, but on four of them. (Ryzen 9-7950 and Ryzen 9-9950)
Our devs think there may be something the matter in the installer itself. To debug further, we ask you to download Microsoft’s procDump so as to create a dump file that they can investigate. Do the following after downloading and unarchiving the zip:
1. Open the WIndows Command Prompt as Admin
2. Drag and drop the procDump64.exe into it
3. Write the following commands afterward (and set the appropriate paths). The whole command should look like this: procdump64.exe -ma -e 1 -x C:/<OUTPUT_DIRECTORY> "C:/<PATH_TO_THE_INSTALLER>/vray_adv_72008_max2026_x64.exe
4. The result crash dump will be in C:/<OUTPUT_DIRECTORY>. Please attach it here.
Along with that, could you also run the installer with -debug=3 mode, like so:
1. Open CMD as Admin
2. Drag and drop the installer
3. Type -debug=3 after the path
4. Continue trying to install from the UI.
5. A temp file named “installer_debug.XXXXXX.log” should be written in the Temp folder (C:\Users\<Username>\AppData\Local\Temp)
6. Attach the .log file too.
Thank you very much for your help. I was able to resolve the issue. I couldn’t open a CMD window, either with or without admin rights (“insufficient permissions”).
So I used the option Settings > System > Recovery > Fix problems using Windows Update. After that, I was able to install V-Ray without any issues. And I can open the CMD window again now.
