Error while loading the plugin
I just installed the wibu-key drivers, the licserver and vray on a workstation with Linux CentOS. Installations went fine, no errors. When i try to load the plugin in maya i get an error:
V-Ray warning: Loading shaders failed: no <*.txt> file in .
V-Ray error: Could not register VRayGeoSun (kFailure): Unexpected Internal Failure
registerTransform failed: (kFailure): Unexpected Internal Failure
Versions:
Maya2011x64,
CentOS 5.4,
Vray build 12830
Any suggestions?
Sorry if this is discussed anywhere else, didn’t find anything.
Thank you!
EDIT: Solved, works now after 2 rebbots and one or two restarts of the licserver and maya.
I looks like the environment variables were not set properly the first few times.
ok, thanks!
I cannot get the V-Ray plugin to work.
I get this in a terminal window when starting maya:
[2014/Oct/6|13:56:15] V-Ray: V-Ray for Maya version 2.40.02 from May 14 2014, 16:13:09
[2014/Oct/6|13:56:15] V-Ray: V-Ray core version is 2.00.02
[2014/Oct/6|13:56:15] V-Ray warning: Loading shaders failed: no <*.txt> files in .
Logging out/in doesn’t solve the problem. Any hints?
Maya 2015 SP4
Slackware 14.1
Vray 2.4.002
It’s the same thing; environment variables are not set up properly. The installation tries to set this up, but maybe it fails to do that for your Linux distribution. There is some more information here (although it describes how to set things up for a .zip installation, it also gives a list of the required environment variables):
Thanks for the reply. I’m using the .zip installation method and I’ve got it mostly working now.
