Maya 2011 SP1 64 for OSX - crashes all the time when I try to render
So I finally got around to install everything, even manually adding an environment variable that the installer wouldn’t create. and the plugin seems to load and all. But if I try to render it crashes Maya and if I go to the console I get the following errors:
Any ideas?! I’m running Snow Leopard (10.6.6), on i7 2.66 macbook pro.
Cheers
11-03-02 10:42:52 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:42:52] V-Ray: V-Ray for Maya version 1.50.SP1 from Jun 11 2010, 17:05:34
11-03-02 10:42:52 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:42:52] V-Ray: V-Ray core version is 1.90.03
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] V-Ray: Starting render
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray: Loading plugins from “./libvray_*.so”
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray: Finished loading plugins.
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray: Exporting scene to V-Ray.
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsEXR !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsPNG !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsJPEG !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsOutput !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsOptions !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsImageSampler !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin FilterArea !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsCamera !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsCameraDof !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsMotionBlur !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin RenderView !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: Could not create plugin RenderView
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsEnvironment !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsColorMapping !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsUnitsInfo !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsGI !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsIrradianceMap !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsPhotonMap !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsDMCGI !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsLightCache !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsCaustics !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsDMCSampler !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsDefaultDisplacement !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsRaycaster !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsRegionsGenerator !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin SettingsRenderChannels !
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray: Translating scene geometry for V-Ray
11-03-02 10:44:22 AM [0x0-0x51051].com.autodesk.Maya.2011[479] [2011/Mar/2|10:44:22] V-Ray error: ERROR: Could not create plugin MayaLightDirect !
Console Messages.txt (10.1 KB)
Hey there,
Does anybody have a clue on what this could be?! Any leads appreciated… :slight_smile:
cheers
For OS X, the V-Ray environment variables are written to the Maya.env file. If you take a look at it, do you see them there? Also, it might be necessary to log out and then back for the variables to take effect.
Hey, Vlado
Sorry for the delay, but my HD fried and it took a few days to get a replacement from Apple.
Anyway, I checked the maya.env and there was no reference to Vray there. I then added the following myself:
VRAY_FOR_MAYA2011_MAIN_x64 = /Applications/Autodesk/maya2011.5/Maya.app/Contents/vray
and it caused the plugin to load fine (i also deleted from my OSX environment variable plist). The same error occurs though and maya freezes and crashes.
Cheers
Since Maya 2011 subscription advantage pack version have all its folders named 2011.5 that may be a problem for V-Ray for Maya to install properly.
We have a workaround that you can try.
Please first uninstall V-Ray for Maya and any third party plug-ins. Then rename Maya 2011.5 folders.
You can do this in the terminal by using this command:
sudo mv /Applications/Autodesk/maya2011.5 /Applications/Autodesk/maya2011
or you can change the default path during installation Maya 2011.5 to match the above.
Last step is to install V-Ray for Maya 2011 and make a test render.
To make sure that everything is set-up correctly please create the default Maya 2011.5 installation folder and to put there symbolic links to the “icons”, “plug-ins” and “scripts” sub-solders which are located in the new 2011.5 folder.
Let us know if this works for you.
Hi there,
I tried your workaround and it didn’t work :frowning:
So I tried something else: I went to the terminal and typed “env” to get the environmental variables and I copied all the vray-related variables into the Maya.env file (which had none prior to this). After doing so, it finally worked!! :slight_smile:
I guess you guys need to add the variables to that file instead cause with them in the system’s environment variables alone it didn’t work, at least in my machine. For some reason vray wouldn’t see them.
Thanks for the help.
Aneurisma
BTW, the variables I copied are these:
VRAY_FOR_MAYA2011_PLUGINS_PowerPC=/Applications/Autodesk/maya2011/Maya.app/Contents/vray/vrayplugins
VRAY_FOR_MAYA2011_PLUGINS_x64=/Applications/Autodesk/maya2011/Maya.app/Contents/vray/vrayplugins
VRAY_PATH=:/Applications/ChaosGroup/V-Ray/Maya2011-x64/bin/x64/vc6
VRAY_FOR_MAYA2011_MAIN_PowerPC=/Applications/Autodesk/maya2011/Maya.app/Contents/vray
VRAY_FOR_MAYA2011_MAIN_x64=/Applications/Autodesk/maya2011/Maya.app/Contents/vray
Cheers
I just found out, digging into my Maya preference files and stuff, that the vray installer did, indeed add the variables to the maya.env, but instead of adding it to my current version of maya (2011.5) it added to the previous version (2011) which was still there in the preferences folder.
So here we go… :slight_smile:
Cheers
