Exclude Sim Grid from Particle Tuner
I’ve got two grids in a cascade setup. Sim1 and Sim2 - I’m happy with Sim1, but I want to control the foam of Sim2 with the particle tuner. How do I stop the tuner from affecting both simulator grids?
You can use the Scene Interaction rollout in the phoenix simulator. There is an Include/Exclude list there. You can choose which objects, sources and emitters any given simulator uses and interacts with. Should also work with tuners.
