Export all views?
Is there a way to export all favorites views, without the need to stand in every view and manuel export?
And could we have the option to autoname the exported view the same as the viewname inside revit? would be fine for my workflow :slight_smile:
Jorgensen
Hi @Jorgensen_dk
actually there is since Enscape v2.2 :wink: At the bottom of the views dropdown you have a Batch Export button that renders all favorite views at once!
Hope that helps! :slight_smile:
that was embarrassing =O
thanks @Clemens_Musterle
Jorgensen
(Note: currently batch renders revert to the default DOF and 90º FOV - if that’s an issue for you, you will still have to do each one manually… until they fix that :wink: )
A related question. Is there anyway to update all renders you have added to revit sheets? I’ve often add enscape renders to my sheets before they are sent to the customers. However if I do any revision I have to render all views manually, then resize it to fit the sheet.
@3DMake Right now, Enscape can only create new renderings in Revit, neither change nor update.
