I want to make favorites in de enscape session. I do that by navigating to the desired view and then ‘create 3D view’ in Revit to make it favorite. I don’t find the create 3D view anymore..?
View management, I think I found it.
Exactly, that is where it has been moved!
If you want to share any feedback with us regarding this new addition let me know as well of course!
Don’t make 3-D views in Revit - doing so requires far too many pics and clicks. Create 3-D view from Enscape and save it back to Revit. In the process you can also favorite the view and apply a visual style. The only thing you need to go back to Revit for is to set the crop region, visual settings, phase, section box, etc. But set the time of day and camera location from Enscape to Revit.
Unfortunately the time of day always flips back to a startup setting (8.30 AM) when opening the view. My setup for a view in Enscape in the beginning is another time, but when choosing the view again, it always start at the default Enscape time…
Enscape is simply displaying what Revit tells it to display. It’s likely you need to set the time of day in the Revit View Properties for the Solar Study value to Still.
You can also go one step further and create a view template that can be applied to multiple views so that they all have the same designated time. If you modify the designated time in the view template it will automatically be applied to all the other views. Here’s the process:
Thanks Phil in advance - I wil have a look into my situation and study your twitterfeed.
Glad to help. If you dig around LinkedIn you’ll find my profile and personal contact details. Feel free to email me if you have any questions or would like to discuss a workflow or best practice issue.
In the last version. I could switch the favorite stars on and of just by clicking on them. Now I have to go in to the edit mode of the view, click the star, save… This is not a good change.
And where is the render Favorites?
Thanks for the feedback - this has been reported a few times now and we’re already looking into ways to speed this process up.
No promises I can make yet when this will be implemented though. Stay tuned and thank you again for the input.
I really miss the favourite view tabs on the side.
The view management doesn’t work the same, it is linked to the active view in Revit, which doesn’t improve speed.
Please bring them back (for example just for the favourites like in the exe export)!
Hi @fkerkhof
Forwarded your request, thanks!
