Export.vrscene Max to Maya
I’m having problems exporting .vrscene file in Max . I keep getting a max Script error (attached). In the Vray export dialog does the vray path folder need to be the same folder as the export path?
I’ve also tried the exporter in Vray RT, but i’m unsure if i’m doing it right. Is it just as easy as Changing my production renderer to Vray Rt and then checking the box “don’t render just export”? and then hit render?.. or do i have to Load up vray RT in the active shade also? does it matter how big my file is?
Any help would be appreciated :slight_smile:
DT
I’m working in windows 7 Max 2012 and vray 2.00
Please download and install the latest V-Ray 2.40 (RT) for 3DS Max build and let us know if the problem persist. There are a lot of bug fixes there related to the .vrscene exporter.
