Hi all. My render farm is set up with Vray Standalone (Maya) and I was wondering if it was possible to render a .vrscene file exported from 3dsmax?
You could give it a try… The best way is to export the .vrscene through the V-Ray RT engine (you don’t need to render it, just export it) or using the respective MaxScript command as described here:
Thanks Vlado. I didn’t even realize that I had to use a side door to get Max to export to .vrscene.
I’ll give it a try.
I keep trying to export through Vray RT but the render dialog say waiting for renderer…How exactly should i set up the Vray RT? in active shade or through production?
Which OS is that? It probably has trouble starting the RT render server - in which case you can just run it manually.
