i testrender my stuff inside maya with VRay VFB and VrayRenderegion.
When i forget to turn off the renderregion and then export to a vrscene and send it off to our farm the images fail to render.
How could i disable the vray region via mel? I haven’t found the attribute yet…or can u fix the export, so the region does not get exported to the vrscene?!?
I have reported that to the developers so they can consider to implement an option for this.
For now you can disable the render region in the V-Ray Standalone by using the option -region=0;0;width;height where width and height are the size of the original image.
Like Zdravko said, you can use the -region option for the standalone to specify that you want the full resolution to be rendered; this will override any region specified in the .vrscene file. I also made a note to allow something like “-region=none” to ignore this region without specifying again the resolution. Another option is to edit the region out of the .vrscene file.
