Hi there,
I’m testing out the new 3dsmax viewport to Vantage link, but I experience the same exposure issue when doing a live link from 3dsmax:
Exposure settings in 3dsmax environment is the following:
This enables me to render perspective views at the correct exposure when I’m not in a camera view.
So when I link the 3dsmax viewport to Vantage it initially displays correct - with auto exposure turned on:
Problem is as soon as I move in the 3dsmax perspective viewport, the exposure is over blown - Auto exposure turns off by itself.
Also, my next step was to change the exposure mode to “Value” and add the corresponding number, but the same thing happens when I move in the perspective viewport - values reset to exposure mode “None” and no auto exposure…
When I look through my camera in 3dsmax and move/rotate through the camera view, the exposure remains correct.
Edit: If I bring down the exposure at the top of the Vantage window to around -5, the display matches up with the 3dsmax perspective viewport.
Then I’m able to move and rotate in the max viewport and the vantage viewport exposure stays consistent with the max viewport.
Looking through a camera though results in a too dark view, so then I have to disable the -5 exposure value.
What am I doing wrong - I can’t seem to get a proper tutorial on this anywhere?
Also, what is best to use in the 3dsmax environment setting:
Physical camera exposure control or Vray exposure control - and why?
Please advise,
Thanks!
