I wish we could choose visually inside the VBR the exposure of the rendering, choosing the black and white level out of an HDR, so it would be much easier to adjust the illumination of the scene. It should be like the Photoshop Level-control, inside the very wide HDI exposure-range, simply choose the black, the white, and the middle point for the output RGB. This would make life much easier (much better than Dark and Bright multiplier).
so why dont you just increase the expoure levels of the HDRI in the Material editor … or have i missed the piont.
Natty
vfb support of hdri
hi yes i think you missed the point, after rendering it would be grate to see your rendering in the vfb (not the hdri you used to make an image) and then interactive change the lighting. that realy would be grate, but what about saving your renderings also as an hdri ore open exr format, and having a plugin from vray for aftereffects and photoshop to control your hdri animation in your compositing program 8-).
a real exposure control for realworld energie distribution. would be good to and … . Renderes are develloping fast. for me never fast enough 8-(.
Tom
