Exposure slider instead of Level in Diffuse slot
Hello guys!
There is no intuitive way in 3dsmax to change the texture exposure, which is sad - because this action is needed 99% of time when working with textures in Albedo-correct way. Most textures are photographed with the wrong exposure, have reflection lighting in them, so they need to be tuned down a bit (or up!).
There are numerous ways of altering the texture brightness:
  1. Level slider
  2. Map % slider (with black color in the color slot)
  3. Output Level inside bitmap map
  4. RGB Level inside bitmap map
  5. Gain in ColorCorrect map
  6. …etc,etc,etc
But NONE of them tunes the exposure. They all tune brightness, so when you make the texture darker - it also looses saturation and contrast => becomes more faded & grayish.
To see what I mean by that - just open any texture in Photoshop, and apply Exposure in “Camera Raw…” filter.
Then open the same texture in 3dsmax and try any of the above ways to achieve the same - and you’ll see the difference between the real exposure, and 3ds max ways instantly.
Also - it’s also much harder to rise the texture exposure, than darken it. So the Exposure slider which can do -/+ to texture in the CORRECT way - will be a great handy tool when rendering objects with photographic textures.
P.S. I could post some screenshots, but I think you should try it yourself to see in your own eyes.
Thanks.
Doesn’t some other slider in Color Correction map change the parameter that you would want (gamma or something)?
I’m not sure but I think when you are editing an 8-bit file in Adobe Camera Raw and you are changing “exposure” value, it does some black magic trickery trying to guess which parts of image are bright and which are dark and tries to simulate what it would do with 32-bit files. But I’m not sure…
Well yes, I can tweak Gain + Gamma + (if needed) Saturation = to achieve similar looking result. But that’s too complicated to get the right looking result by tweaking 3 sliders instead of one.
Yes, you’re right about 8-bit file, the most majority of textures on the web are 8-bit files, actually. But I’m sure that the black-majic-trickery formulas of doing this are available somewhere in scientific papers. Or can be reverse-engineered from camera-raw by tweaking different gray (or not gray) gradient files, and looking how it works.
Well, if that’s exactly same, then maybe you should look again at it?
(Left is 3ds max output 0.08, Right is CameraRaw -3 EXP)
And please don’t say the left grayish thing is okay for you, and artistic, or whatever.
Eveyone knows about 8bit, 32bit - that’s school knowledge. But why even Nuke handles THE SAME 8-BIT FILES much better?
Everyone knows that 32bit textures are much better, but where do we get them? cgtextures, etc - everything is 8bit. We’ll wait for Megascans of course, but it’s still not here. So all we’re left with - is doing the same procedures we did, using 8bit ones that we have on the web.
And you know, I’m perfectly okay with loading adobe photoshop with each of 100 textures I have in scene, and tweaking it there with camera raw, then reloading and rendering it in Max. Also I’m okay with tweaking the curve in output, or gamma in ColorCorrect.
The same way I was okay with putting 10 negative values Omni’s to fake Radiosity & Global Illumination.
Because there was just NO OTHER WAY.
And I completely understand the marketing strategy of Corona as “Same as Vray, but a bit better & faster”. So I understand why everyone’s so conservatively wants to keep the interfaces same & old-school.
But seriously, staying so conservative in such fast-developing world can play a bad joke on everyone. More & more renders & real-time engines are stepping on, with much simpler & more realistic “out-of-the-box” methods. So it’s wise to think on how to make it more better & easy-to-use.
And some day the step away from Vray&Co will be made. The question is - who’ll do it first.
P.S. Here’s the original texture for tests: https://dl.dropboxusercontent.com/u/9944031/PlywoodNew0011_2_L.jpg
Not really. Everyone wished for GGX so they could avoid absolutely bothersome stacking of multiple specular layers. RGB curves was completely other thing, that was to get slightly unique color behavior for metals instead of single shade but that was even more over the top. But not so much GGX, which does all that with single internal algorithm. Necessary for life ? No, nothing is. But then why even bother with anything new ? How can you at same time defend software with unique and novel approach and at same time, always reserve that same opinion about any sort of progression that’s not in line with your current understanding of workflow. You’re not even on same page with your stuff.
And regarding your overused argument with Alex Roman and Bertrand (or other outliers) having zero problems making nice stuff. Except that Bertrand reiterates his workflow every few months and it takes him quite effort to do what he does and yeah, I don’t think few outliers identify the critical mass of users just because they manage to utilize extreme out-of-box thinking and peculiar attention. Most do not. And neither of those two needed Corona (or even use it daily for that matter), so who do you think this software is actually catering to ?
With that I agree with you not every addition is necessary I also like simplicity of Corona because it doesn’t add stuff. But there are changes that arent’ addition, but could streamline the workflow a lot who wish to to “easily” achieve photoreal results. Which after all is like the main motto behind Corona renderer.
Ad Examples: Almost every of your argument is logical fallacy or doesn’t apply to topic you illustrate. What does the correlation of users’s quality of work have to do with usability of renderer ? All these minor-market renderers like Thea, Indigo,etc.. only showcase they never attracted critical mass of users among which few outliers could demonstrate their highly above-average skill. Yet give it to that outlier and he will largely exceed their portfolio (Bertrand with Octane, Maxwell, Corona,etc… not only Vray).
Can we apply reverse logic to that ? MentalRay has some of the most amazing work on internet given how long it is on market and how large its userbase used to be (and probably still is). Does it prove Mental Ray’s superiority in usability against others ?
It doesn’t, and neither does your point.
This is seriously derailed. I dont see merit in implementing anything here - exposure can be changed via other ways.
