zoranm
1
As title says:
Is there a way or plugin to convert HDRI/EXR format that can be imported as camera raw CRW or DNG format into Photoshop?
Contrary to reasonable expectation, photoshop can’t do it: it creates corrupt files!!!
I did a 2 h search and couldn’t find anything usefull on the net
Thanks in advance
Zoran
U dont have too
Open AS
Select file
select extension RAW
Done.
zoranm
3
Dadal,
Thanks for replying.
I’m still having the same problrm and error messgae:
“Could not complete your request because the
file-format module cannot parse the file”
I’m on PS CS4 64-bit version (11.01) / WinXP.
Can you, actually, Open As without error?
regards
Zoran
uuu I got it too, it works for tiff16 bit tho.
Well I have a feeling that u can’t run with 32 bit float image in RAW mode. They aren’t design for it… DSLR only runs at 16 max if I’m not wrong…
zoranm
5
I’m on cs4 standard.
It might be working in “extended” version ( apparently it supports 32bit)
Could anyone on “extended” check this?
Thanks for replies
Zoran
