Exterior ... first step with vray
Hello!
I’m finishing this job …
Comments and criticisms are welcome!
modeling: Sketchup_100% Autodesk_ADT2009_10%
render: Vray_100%
photo retouching: Jimp_10% Piranesi_200%
original image
piranesi image
davide
Re: Exterior … first step with vray
Interesting style you got there, very picturesque.
Very nice man… i agree, very interesting style, how u did?
For the “photo retouching” I use Piranesi useful for creating effects “hand made” but very useful to adjust the images using the depth, the orientation of faces, the material … in short, what about more try! [Www.informatix.co.uk]
(((… I do not have fees for this !!!)))
hmm,.,the stle of piranesi effect is good..i also used piranesi for sketchup before for the great water color or sketch effect…IMHO in your design is good..in 1st image it looks like a draft output..i did not see any vray materials apply in your model…i dont like the trees there.,..maybe try to put other trees.try to use hi resolution materials for your grass…thats all post more
vhin It was true!
I have not used, practically, special v-ray materials,
I preferred to change some parameters for materials from SK … for example the roof, the floor, the bodies of the machines.
If I had had more time (also I am a beginner and then use very long time to understand, try …)
I would have felt better grass (as explained and widely shared on the site!)
I am satisfied texture that I had because I wanted the final effect ce was tried in the water-color sketch … Made in Piran!
>>>> Plants … Plants! I’m desperately looking for a software that can create good models tend to very light (with the help of billboards) will ever succeed INTENDING?
>>>> Can you lead to a good setting for type material of lime plaster - cement? what parameters should mainly control? (excluding a good texture!)
