Hope you like it..!! ![]()
Beautiful pool texture. Do you mind sharing with us how you have created the water material?
Thanks for the Appreciation.![]()
Well , As we all know and do…I have added water material in Sketchup itself and adjusted the opacity…then with Enscape material editor…I changed it to water and then did all the settings as per the output i want like the intensity , height etc…and mainly the surface the tiles and the surroundings , shadows everything matters …And there are many other ways to get that kind of output… weather it can be through using seamless texture image , Enscape water material from Enscape material library etc.
Hope It will be helpfull for you.
if only I had become a farmer! ![]()
