FEATURE REQUEST - Rotate before placement
Hey,
I was wondering if it was possible to have a rotate shortcut key before you place an asset.
Say you click an asset from the menu and before you place it in the model you can press the spacebar and the item will rotate clockwise at 45 or 90 degree angles.
From here you can then go into the normal rotation and tweek in detail.
I use Enscape for interior design and architecture and its time consuming to have to rotate every item 90 degrees so they fix to walls
Thank you
