I noticed an unusual slow down with Flextools including a status bar and Flextools prompting if I want to continue with the modifications.
Examples when stretching windows.
With V-Ray Disabled:
0.4209259 seconds to redraw
0.4221024 seconds to redraw
0.4240048 seconds to redraw
0.4263231 seconds to redraw
With V-Ray Enabled:
2.8490893 seconds to redraw
2.7907658 seconds to redraw
2.8031795 seconds to redraw
2.8167275 seconds to redraw
This is using Sketchup 2022.
Slowdown not present in Sketchup 2021.
No errors in Ruby Console. Just times.
I reinstalled Flextools and it’s back to normal.
Getting a little jumpy of late.
Feel free to delete this post.
Edit: Spoke too soon. It’s still running slow.
Update: Ran Sketchup with a clean plugins folder and Flextools and it’s running fine with V-Ray enabled. Then on a lark I installed Skatter and it’s slowing down again. Removed Skatter and it was back to normal. I went back to my new filled up plugins folder minus Skatter and Flextools is still running fine. This might be juggling but there seems to be some compatibility issues on several level and everyone is catching up with SU 2022 changes.
Hi gus_robatto,
We’ll try this here and get back to you.
Konstantin
Hello, Gus,
Our developers are now scheduled to look into the nature of the conflict between V-Ray and Flextools. Based on their findings the team will proceed with either devising a solution or reaching out to Flextool’s authors.
Will post again once the details surrounding this compatibility issue are clarified.
Kind regards,
Peter
