Flickering Lights in Video Rednder
So I have rendered an animation in Vantage. The original file was created in 3ds max + Vray 5. The problem I am facing is that there is inaccurate light intensity in each frame which is resulting in flickering lights in the animation. I have attached the setting that I have used. Also the video link is here
- https://youtu.be/tyuIXGmhkv4
The Graphic Card that I am using is RTX2080 Super
Please Help !
By the looks of it, it seems it’s the effect of the denoiser. For animations I’ve found that I’ve had the best results turning it off. But perhaps someone more experienced can provide a better answer.
Did you try rendering the scene without the denoiser as suggested ?
It’s also possible that this is caused by the light cache.
You can try increasing its Sample Limit and/or Retrace Thresh. from File → Advanced Scene Settings.
You can also try disabling it.
It will be helpful if you send us the scene for testing.
Greetings,
Vladimir Nedev
