In my Enscape walk-throughs, lights and surfaces will randomly stop and start illuminating or reflecting lights through out a video.
Any idea what could be causing this and if it is something I can prevent? I would like to hear any workarounds if they exist, but I am looking for a long term solution.
This occurs in fully rendered Enscape videos. This issue does not look like zfighting.
Below is an animated .gif of the issue. Different areas of the gif show the issue but I’d like to focus your attention to two points:
the front of the sofa chair
the back of the arm chair
Thank you everyone
Which version do you use?
I’m currently using 2.3.2.4
We have not seen this issue before. Thanks for reporting.
- Please try the Preview version (you find it on the download page). Maybe this issue is already fixed.
- If not, please send us a repro-case (can be just a fraction of your project) to . We will handle your files confidentially and delete them after fixing the issue.
I’m talking to my IT department about this since they would be the ones to install the preview version.
I’m surprised this is the first you are seeing this issue. I thought this was a common issue.
Well, there are various kinds of flickering, popping etc. This particular one looks kind of new at least and is not by design for sure. That means, it should be fixed.
This issue seems to be solved in the preview version. Thank you.
They was still one slight flickering area in the same walk through, but I really had to zoom in and look for it to see that issue.
