Floor generator - Invalid input mesh detected
Hi, I have a problem with the floor generator plugin. When I apply a floor generator modifier to an irregular surface, the message “invalid input mesh detected. Floor Generator requires a complanar base object?” Appears and 3dsMax turns off. Have you encountered a similar problem? I tried to reset the Pivot Center, but it doesn’t help.
Here is a screenshot: Przechwytywanie hosted at ImgBB — ImgBB
Thank you in advance for your help, best regards
Have you also tried contacting the makers of the plugin to see if they can help? Just in case the community here hasn’t run into that issue.
Floor Generator requires a flat surface (e.g. a rectangle, circle, etc). It will not work on 3D surfaces.
