Flower meadow at sunset
Hello everyone,
is there a way to know how many polygons are in an Enscape scene?
We do not support displaying of the amount of polygons of your scene through Enscape natively - If at all you’ll have to check that via the CAD solution itself, which may be possible depending on which you are using. What CAD software did you use for these renderings?
This is SketchUp, and a lot of Skatter objects.
Why can’t the animation be seen?
If you are using SketchUp you can find the number of faces in your model quite easily.
From menu bar
Window / Model Info / Statistics
Make sure you click show nested components.
I also use a great plugin called CG Impact Report - It details the quantity of each component and the total number of faces for each so you can see what the heaviest components are.
Cheers, steve.
Thank you Steve,
the problem is that with the method you describe i get the number of polygons in sketchup, but as most of the objects are only loaded by Enscape’s rednering engine, i cannot know the number of polygons rendered.
Here is a short video of the scene:
https://www.cad3d.expert/Flower%20meadow%20at%20sunset1.mp4
