Texture and Polygon reporting
Would be great to have a tool in Enscape to generate an exportable listing of all the textures in use in the model, providing their name, path, and pixel dimensions. This would help users realize when they are using something that’s too big, not found, or not necessary.
The tool could also report how many polygons are active in the chosen view in Enscape
Thanks a lot, I’ve gladly filed and forwarded your feature request accordingly - much appreciated!
If you’re using SKP there’s a extension called Material Resizer: https://extensions.sketchup.com/extension/77b60f26-2352-407e-8c0c-9862c9716111/material-resizer
But yeah, having a way to show things such as poly and face count, gpu and gpu memory load and so on would be very appreciated.
