Focus distance makes image darker when set under 10 units...
hi,
ive a prob with focus distance and lower values than ca. 10 units..
When I render the scene without DOF everything is ok.
Than I switch on DOF with specify focus on too.
When I use a focus distance from 25 units or more, everything is fine too.
No changes in brightness.
(higher values are fine too)
When I set focus distance to 5 units, the result becomes much darker.
The scene units are centimeter.
Maya2011, vray 2.004, Win7
Its a big prob for me, because its not posible to rescale the whole scene in this case.
Is this normaly?
What can I do?
Thanks for help
no ideas?
I made a little testscene to show the prob clearly.
Simply load the scene and start RT engine.
Then scroll from frame 1 to frame 75 and ull see what happens.
For me its a big prob in my actual project, because most take have less than 10 units foacal distance.
I can understand, that phys cam makes it darker, when zoom is the theme.
In real it is the same.
But when I simply fly more near to an object I cant see any reason for massive brightness changes!
What can I do?
I have the same problem…
We added this issue in our “to do” list.
Thank you for your feedback.
thats great.
thanks for response :slight_smile:
