Focus NOT working
Hi all,
I recently found the focus in enscape does not work properly. It used to be fine but now I cannot set the focal point. No matter what distance I set, it still focuses at a very short distance. Below is the image for reference. I set the focal point at 8.25m but it is actually around 1m in the image generated.
The image looks perfect when the depth of field is set at 0. However, I cannot control the focal point anymore once the depth of field is not 0. Would anyone have the same experience before?
Thank you very much!
Hiu
I am sorry to hear about that and thanks for your post, plus welcome to our forum. :slight_smile:
Have you made sure that you simply did not link some visual setting configuration to these specific views where you’re having the depth of field applied close to the camera?
Furthermore, you should be able to control the Focal Point when Depth of Field is set above 0, you actually should not be able to control the Focal point when Depth of Field is set to 0%, since that would just mean it’s disabled anyway. Also, make very sure that you’re not having “Auto Focus” enabled since that disables the ability to set your Focal Point manually of course.
In this case, would there be a chance to record this behavior since I have not received any reports about this so far yet. What you may try as well is simply re-install Enscape - this may already help too.
