2.7 Version "Focal Point" / "Depth of Field" issue
Running into an issue with using the focal point / depth of field feature in the new release 2.7 Revit plugin. When the focal point feature is activated a narrow slice in the model appears which burls out the front portion and back portion of the image. The “slice” seems like it can not be modify / increased. We are able to move where the focal point is set but unable to change the depth of field as it correlates to the image. Please advise
? I just slide the Depth of Field slider (above the Focal Point slider) and it changes.
I saw this happening in mine as well. I found that if you move around enough and play around with the slider a few times eventually Enscape releases the DOF and you’re able to move it around like in previous versions. It appears to be just a hiccup.
@Archytextural_1 , that does not sound right though - sometimes you’re moving the slider and simply nothing happens to the DoF indicator? Does his issue occur with every project and/or is there a way you can reproduce this? In any case, it would be great if you could send in some feedback as well - maybe the log files give us further hints as to why you experience these “hiccups”.
The next time I see it happen I will send it your way for sure. I’ve only experienced this with the new 2.7. To be clear the line for the depth of field moves through the model it’s just the focal point doesn’t change. It stays out of focus. I can increase the DOF effect and try the slider again it just all stays out of focus. Give me a chance to try and consistently recreate it and I’ll send the feedback for you.
Thanks to the whole team for a great product.
