Hi there,
seems like follow mouse in the vfb isn’t working anymore. Using latest update on Rhino 8 latest update. Please fix! Thanks
Toni
Hi there,
Toni
Hello @Toni_Schade ,
I am not able to reproduce the issue with V-Ray for Rhino 7.40.02.
Could you please check if “Lock bucket starting point” is disabled? You can do this by right clicking on the VFB render view when Follow mouse is enabled. If “Lock bucket starting point” is enabled, rendering always starts from a fixed point.
Additionally, what render mode and engine do you reproduce the issue with - Interactive, Progressive, Bucket, CPU or GPU? Do you use multiple monitors? If possible, could you please send a screen recording where the Follow mouse issue is visible?
Kind regards,
Iva
Hi Iva,
Thanks for the quick reply. “Lock starting point” is disabled.
I am working on 7.40.02. Production buckets render CPU. I am using two monitors and it does not work on any of them. Screen recording is not really possible at the moment.
Thanks!
Toni
I’m also unable to reproduce this on my end, which suggests it may be environment-specific. Would you be open to a quick remote session so we can take a look together?
Hi Svetlozar,
Thanks for getting back in touch. In this very moment I figured it out myself: It happens when DR is activated in the main settings tab and no slave is listed. Same issue then with the split buckets btw!
Best
Toni
