footage on a plane
Hello!!! I can’t get , either in AVI or TGA sequence, a footage working on a planre, in an animation… Seems that thez “calculate” function don’t work!.. I there is something to do???
By default, this will only show up in the final render. If you’re trying to view the animated texture in the viewport when you hit play, you will need a standard C4D material and under the editor options turn on animate preview. :wink:
