Problem: when reviewing the design in Enscape the customer often discovers something that should be modified or changed. However, the Enscape view is independent of the design application view.
Challenge: The customer must spend time accurately locating the issue in the design application. Buildings contain repetitive relationships. In a large design file with considerable repetition there is uncertainty that the design issue viewed in Enscape matches the design issue being viewed in the design application.
Solution: A “Go To” button. One button in Enscape to frame the design view in the design application to match the design view in Enscape. This saves time and removes the stress of uncertainty and allows the customer to quickly and easily make the design change in the design application that was discovered in Enscape.
Submitted on AHA Ideas (ENSCAPE-I-1508).
