I am able to reproduce following bug:
3ds Max 2016
Corona 1.6 Hotfix 1
Create a Free Camera
Enable DOF
Enable Geometry Motion Blur
Enable Auto-Key
Start IR (i used the IR in the Quad View)
Animate Target Distance
→ Freeeeeeze
3ds Max 2016
Corona 1.6 Hotfix 1
Enable DOF
Enable Auto-Key
→ Freeeeeeze
Thanks for the report and sorry for the delay. We will look into this…
I could not reproduce this in Max 2017 Corona 1.7 (04.07). Either fixed, or does not happen in these versions.
If anyone can reproduce, please report.
Can confirm the freeze with Max 2016/Corona 1.6.1
I´ve sent a minidump of the freezed state as “FT_16331_KeyingTargetDistance_3dsmax_2016.7z” via private uploader.
Good Luck
Any progress on this? ![]()
Its still freezing on DB 2017_09_19
we will look into this today
I was not able to reproduce this bug. I have tried it with both the latest daily build and Corona 1.6.1 in 3ds Max 2016.
Are you sure there were no other steps involved in producing this bug?
It would help us a lot if you could send us some simple scene where this occurs.
Reproduceable here with our (almost emtpy) startup scene. Do you still have the minidump? Make sure you have the Cam’s view in the viewport to get the freeze.
Good Luck
I just uploaded a minidump too. Max 2016, 1.7 DailyBuild Sep 18 2017
In the scene there was just a free camera, nothing else.
Geometry-Motionblur enabled, DOF enabled, IR running → “autokeyed” Target Distance in camera → freeze
I have checked both the minidumps and it seems you are using older version of 3ds max 2016. You need to update to the newest version of max 2016. It is highly likely it will solve your problems (I don’t experience any freezes in the newest max 2016).
You mean SP4?
I have just uploaded “FT_16331_KeyingTargetDistance_3dsmax_2016_SP4.7z”
Thanks and
Good Luck
Yes, SP4 should be the latest version.
Which version of Corona did you use (to create the last minidump)?
Since I am still not able to reproduce this problem, it would help me a lot if you could send me a scene, where you get this freeze.
I know the setup seems to be very simple, but sometimes even the slightest detail can matter a lot.
Thanks.
I was finally able to reproduce the freeze with slightly different steps (clicking on “Set keys” seems to be vital)
The freeze is fixed and the fix should appear in any next RC.
Oh, sorry, I thought it was obvious (filename ending with “3dsmax_2016_SP4”).
Glad you found it finally!
Good Luck
