your right, i downloaded both rhino and vray trial version… just the problem is learning curve. rhino seems like autocad ah and vray rhino is exactly the same vraysu.
of topic (sorry) is it possible to use those visop and su mat doen in sketchup to rhino?
Yep, visopts and materials can go back and forth. The only thing is to make sure that the materials aren’t linked materials as I’m not sure what they will do in vfr.
I would suggest that you try and ride out the learning curve for Rhino. I personally don’t think its that hard to pick up if you have some AutoCAD experience. Your going to want to use commands to do certain things. Each command is fairly specific as opposed to the general tools that SU has. For basic stuff, SU may be quicker, but once you start getting into complex stuff or organic forms, you’ll find that Rhino is much better.
Thanks for taking it for a spin. Making options “sticky” is something that I’ll be looking to implement, but in the long run the intent is for their to be a dialog box which will make setting all the options much easier. Since the idea is to have it “macro-able”, they the command line still does need to be available, so I’ll try and get it working.
