Hi guys,
I downloaded Corona today, very impressive! Also great fun. Could someone tell me is there a way to change the intensity of the GI?
Thanks a mill
Hi guys,
Thanks a mill
You need to go at the true physical path - decrease a diffuse level in everyone material
Global level of GI don’t has a setting. Of cause you can try decrease a Max ray depth - but it would be a wrong way and will give you a bad result
You can increase MSI but, if it will work in your case at all, then only to some degree. You can also simply increase EV value making your scene brighter. Or maybe you mean something different?
Thanks for the reply’s lads, not too sure I phrased it correctly in the first place.
Say for example I want to reduce the bounce influence from a wall/floor onto other objects (without tweaking the diffuse settings in shader) is this possible?
What do you mean by MSI?
Is there a similar thing like in Arnold similar to diffuse ray depth which controls the amount of bounces allowed in a scene?
